2010-02-24 01:37 PM
2010-02-24 03:23 PM
2010-02-24 07:45 PM
2010-02-24 11:49 PM
2010-02-25 12:13 AM
ar_raneem wrote:Right. The hotfix process updates any installed add-ons, so it is possible that you installed an older version of the 3ds-in addon after applying a hotfix.
i 've jsut opened the add-on manager and it seems that my file is outdated on. need to get a new version, right??
2010-03-01 09:18 PM
2010-03-02 02:45 AM
ar_raneem wrote:You can save to 3ds only when you are in the 3d window of archicad, so go to the 3d window and then from File > Save as> you will see the option to export to *.3ds.. hope this helps!
Hello Karl,
still the same prob. now that add-on manager shows that 3d studio in is ok. i still can't use the the 3ds files. can't find it neither in file menu nor in design extra. heeeeeeeeeeeeeeeeeeeelp😞
thanks again
2010-03-02 09:55 PM
ar_raneem wrote:i don't want to save 3ds files, i want to use them but i can't
Hello Karl,
thanks again
2010-09-20 04:40 PM
The file is an outdated Add-On that cannot be used with this ArchiCAD versionIs there a way to import .3ds files into Archicad14 / MacOsX ? The suggestion above doesn't work and I have no option to update in the Add-on Manager.
2010-09-20 06:10 PM
rfinnegan wrote:You have to download and install the add-on. Go to the AC 14 Help Menu > ArchiCAD 14 Downloads which will send you the the web page for the 14 "goodies" including 3DS In.
