3dstudio in is not working in archicad 13
i ve downloaded the add on, but i can't see the 3dstudio in when i launch archicad. when i click on design, design extra, i can only see only roofmaker and trussmaker.
could u please help.
thanks in advance
11 REPLIES 11
David Larrew
It should be embedded in the "File/File Special" pull-down menu.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Open Add-On Manager and verify that there is no error message associated with the 3DStudio In add-on. As seen in the attached screenshot, the add-on itself will place its menus where you anticipated them: Design > Design Extras > Import 3D Studio file
Many people like David use their Work Environment to put this into the File Special menu as well, as it makes sense to be there from a consistency point of view.
Hello guys,
thanks alot.
i 've jsut opened the add-on manager and it seems that my file is outdated on. need to get a new version, right??
thanks again
Right. The hotfix process updates any installed add-ons, so it is possible that you installed an older version of the 3ds-in addon after applying a hotfix.
Just go to the Help menu to get to the goodies download site to get the updated add-on (assuming that the most recent one for today's hotfix has been put there already).
Hello Karl,
still the same prob. now that add-on manager shows that 3d studio in is ok. i still can't use the the 3ds files. can't find it neither in file menu nor in design extra. heeeeeeeeeeeeeeeeeeeelp 😞
thanks again
Srinivas
ar_raneem wrote:
Hello Karl,
thanks again
You can save to 3ds only when you are in the 3d window of archicad, so go to the 3d window and then from File > Save as> you will see the option to export to *.3ds.. hope this helps!
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
ar_raneem wrote:
Hello Karl,
thanks again
i don't want to save 3ds files, i want to use them but i can't
The file is an outdated Add-On that cannot be used with this ArchiCAD version
Is there a way to import .3ds files into Archicad14 / MacOsX ? The suggestion above doesn't work and I have no option to update in the Add-on Manager.
Thanks.
You have to download and install the add-on. Go to the AC 14 Help Menu > ArchiCAD 14 Downloads which will send you the the web page for the 14 "goodies" including 3DS In.
