AC 10.815 bug / Unable to save / publish DWG
SUMMARY
As mentioned in another thread AC 10.815 is sometimes unable to publish and or / save to DWG.
DESCRIPTION
I have a number of 10.0 files in which publishing to DWG will fail on some stories and sections/elevations.
Some stories/sections can be publish, others can't. I have even tried to delete all entities on a story which couldn't be published to DWG. Put even then I am unable to save or publish too DWG. And yes, I have tried different translators …. with no luck.
Saving a story / floor plan to DWG will give me a "Cannot write output file" error message. Publishing the same story will mark the file / item with status "Failed". Double clicking the list item gives me a nondescriptive error message: "Publishing of the item failed because ArchiCAD was unable to generate it."
This has happened to multiple ArchiCAD 10.0 projects / files. There is no clear pattern. I am able to publish some stories, and some not. Yesterday suddenly I was unable to publish story 1 in an ongoing project. This story has been published many times before, but not anymore now. (Deleting all entities will not help. Deleting all entities, saving, closing file, closing ArchiCAD, reopening Archicad, reopening the file and publish will not help.)
This is a real showstopper. I can't send DWG files to the engineers anymore. Graphisoft must have a look at this immediately!
REPRODUCE
No problem to reproduce on my system ….with given files, it's always like this
SOLUTION
a) Wait for bug fix
b) Workaround:
Save to AC9. Export from 9 (after loss of all special 10 entities).
Screen shots.
a) Error message
SYSTEM
ArchiCAD 10 build 815 INT on Win XP Pro sp2
AMD Athlon 64 X2 4400+, 2DB RAM
ATI Radeon X1800 with dual DELL 24" LCD
17 REPLIES 17
Thomas Holm
I have to agree with you. There are bugs in the DWG translator of AC10-815/817. Some of them are severe. Graphisoft should not hesitate to release a fix immediately.
As of now, it seems that they're waiting for the Macintel release to send out a unified "fix all" hotfix. I find this is OK for lesser (perhaps annoying, but not critical) bugs, but this one really is a showstopper.
I think Archicad resellers all over the globe have the responsibility to inform customers that rely on correct DWG handling that they should wait for "hotfix 1" before finalizing their transition to AC10!
Aussie John
As a workaround can you save from the layout rather than the model?
Cheers John
[/size]
No, can't save/publish from a layout.
.... Update
I have to correct / clarify my self.
I am able to publish a DWG file (of problematic stories) by publishing a layout to DWG.
But there is a big problem: There are absolutely no entities in model space, and the drawing is inserted in paper space as a single block. Exploding the block will reveal that all entities are on layer 0. Useless.
Translator options
Paper Space with Full Drawings content + Single DXF/DWG-file
and
Paper Space with Full Drawings content + Linked Xref drawings
... both create the same useless result.
Using translator options
Models Space as Flattened Drawing
gives: "Publishing of the item failed because ArchiCAD was unable to generate it." error message ....
....somebody has moved this thread from other problems to "Data Exchange and Information Sharing." ??
Gorazd
I had similar problem wit publishing to DWG. After slowly deleting objects from a storey I found out a strange thing, that the problems were on a storey below the "problematic" storey. And the problem was in Window/door marker. After switching markers off, or change them to our old markers it started to work. Dont know if it helps in your case but, I saved to AC9 and publish from there.
Gorazd Rajh
From AC 6.5 onward, Ryzen 9 5900HS, 48 GB RAM, RTX 3080, Win 11
owen
This may not have anything to do with the issue but are the drawings on the layouts you are trying to publish set to Automatic Update?
I was getting the very same error message (and useless explanation) when trying to publish both DWG and PDF. I thought it may have been caused by the publishing action timing-out as AC was taking too long to do the whole BG AC update thing, so I switched them all to Manual Update and the problem went away ..
v10 Publishing Auto-Update Drawings Failing
[Edit:] Should have read more carefully - i just noticed you were trying directly from the floor plan too so I guess it must be a different problem. In my defence it is 6:30pm on a Friday and im a few beers down
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Does anybody at GS care about this?
This is a disaster for my ongoing project. ... Can't send DWG files to the engineers.
Fix is need immediately.
I have been tracking down the problem to one door placed 2 stories above the problematic story.
Deleting the door makes saving / publishing to DWG possible (2 stories below).
Even more important; changing door anchor from "Sill to Story3" = -175 mm to "Sill to Story3" = 0 mm or to "Sill to Wall base" = 0 mm, also makes saving/publishing possible. (Wall bottom is 175 mm below Story 3).
Some self-healing occurs, ... sometimes. After changing back to using "Sill to Story3" / - 175 mm it is sometimes still possible to save !!! (I have tried this multiple times.)
Lesson learnt: using anchor point "Sill to storyN" can introduce errors in the project file.
There is a bug her. GS please investigate.
PS
It is no problem to save/publish the story in which the door is placed.
The wall is shown on "Own Story Only" and "Symbolic Cut"
DS
In another project file I have tracked down the error to windows with anchor point below the wall.
No problem for ArchiCAD unless you try to save to DWG (the story below) …
Lesson learnt: don't put doors / windows below wall bottom until AC 10 is fixed.
… know I have to get some real work done.
Well - here it is the 19th of the month and still no fix. Cannot save two of the stories necessary to transfer DWG's. Two calls to tech have so far not received a response. This type of difficulty should at least result in a posting of intent?????
GS - GET THIS ITEM FIXED ASAP
Lew Bishop
Jon Worden Architects
G5 dual 2.0 4GB dual 20" cinemas
OSX 10.7 AC10
