canvea
Unable to publish specific PDF
Hi, I get the error message "Publishing of the item failed because ARCHICAD wa unable to generate it.".
This concerns only one specific PDF (so far), with the same settings as the others saved in the same way to the same folder. I tried deleting the previous PDF in the folder, and was then able to publish, but the PDF had no data and could not be opened.
Any suggestions?
AC24 Norway • Fujitsu • Intel(R) Xeon(R) W-2123 CPU @ 3.60GHz • 32GB ram • Windows 10 Pro • NVIDIA Quadro P4000
Hello canvea,
I think you should give more explanations :
- your OS
- your Archicad version
- your Archicad update
- and some screen captures
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
