Unable to publish specific PDF
canvea
Hi, I get the error message "Publishing of the item failed because ARCHICAD wa unable to generate it.".
This concerns only one specific PDF (so far), with the same settings as the others saved in the same way to the same folder. I tried deleting the previous PDF in the folder, and was then able to publish, but the PDF had no data and could not be opened.
Any suggestions?
AC24 Norway • Fujitsu • Intel(R) Xeon(R) W-2123 CPU @ 3.60GHz • 32GB ram • Windows 10 Pro • NVIDIA Quadro P4000
1 REPLY 1
Hello canvea,
I think you should give more explanations :
- your OS
- your Archicad version
- your Archicad update
- and some screen captures
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
