AC 10 Font Encoding
PROBLEM: when publishing a PDF (via Amiyuni PDF Creator) from AC, the text characters are scrambled up when I open the PDF in Adobe Illustrator.
The PDF properties show the font encoding as CUSTOM (when it should normally be ANSI).
The tickboxes for font embedding and multilanguage support in Amiyuni are checked.
NB. In the registry encoding is by default set to ANSI_CHARSET
Regards,
Juhan
0 Replies 0
