AC-13 Window Schedule not updating
Window Schedule does not update my changes to IDs. Neither the actual schedule nor the view placed on layout.
I have hit the update button, used the drawing manager to update all drawings, and repeated the above with computer restart.
Thanks for the Help,
Snap
PS New machine and OS.
3 Replies 3
-are the ID actually changed? Does it change in the markers on the floorplan?
-do you display the correct parameters in the schedule?
-are layers locked or hidden?
-are you using modules?
HTH
MS,
Thanks for the thoughts.
I looked into them, to no avail.
When the answer comes, it will be totally obvious...
Guess I'm just gonna havta rebuild the sched from scratch.
Snap
MS,
I said it would be simple. As usual chalk it up to User error.
My error was to change the "Custom Text" field in the Dimension
Marker sub-palette, I should have changed it the Listing and Labeling
sub-palette, where (duh) the ID used in the schedules is kept.
Oh well,
Snap
