AC12 export to DWG problem
Hi everybody!
In AC12 (Win XP SP2, P4 2.6 GHz, 1 GB RAM), when putting on layout drawing, created from view in 3D window, and exporting the layout to Autocad, in paper space appears only empty frame with title and there is no corresponding data in Model space. In v. 9 Plot Maker converted such cases without any problem. In v12 the conversion is done correctly only if "Paper space with drawings as blocks" is selected. But the result is all other drawings in the layout (plans, sections etc. views) are converted to scale, not with their real dimensions. To have Model space real dimensions drawings AND authentic layout image in Paper space it is necessary to copy 3D window as 2D lines in plan, section or detail view and import it as drawing on the layout. Therefore, data refresh will be manual and complicated.
Does anybody know more elegant way to solve this (registry settings etc.)?
0 Replies 0
