Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
AC14 Scheduling Walls - Story Bug
I am creating schedules of my BIM that are producing quantities, lengths and areas of all building components for the QS. When creating a schedule for Ground Floor walls, even though I specify 'Story = 0' as a criteria it is scheduling walls on every floor.
Is this a known bug or is there something wrong with my BIM? I did not set all the walls to show on all storeys, they were set to only show on home storey.
I can (have) shown the storey as a criteria and can only look at Ground Floor walls and ignore others but it worries me that such information can sneak in when you have created a model and schedule correctly and put a huge amount of time/effort into making sure you have an accurate and complete BIM.
1 REPLY 1
I've just realised that I am an idiot, why would I create a separate schedule for each floor when I can just subtotal each floor on one schedule? One weeks paternity leave and my brain's turned to rot.
It's still a bug though but thanks Graphisoft, for once your ineptitude has balanced nicely, rather than compounded, with my own and produced a satisfactory, time saving result.
