ARCHICAD campatible With Form Z
How well is Form Z Compatible with ArchiCAD? Our Designer uses Form Z and when I import his Dwg's file they groups as one complete object. I can select the object and view it as a 3D as one complete object, but i would like to select one single item in his drawings and view it separately. if i explode the objects it becomes flat which does no good to me. I'm working with ArchiCAD 11 now.
4 REPLIES 4
Erika Epstein
If they can export an IFC model from form Z you can import it retaining the individual parts.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Now will this work with Sketchup as well?
Erika Epstein
Models direct from sketchup take a lot of cleaning up to be useful in archicad.
For use in archicad, you are better off recreating it with archicad tools.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks for the Info. My designer has the latest version for Form Z and IFC Model was not and option. Now he would have to export correct and not save as?
thanks one more time for the info
