Adding multiple "Additional Object Parameters" in schedule Criteria
Is it possible to add multiple "Additional Object Parameters" / "Library Part Parameters" in schedule Criteria? I am working in v.22, have not tested other versions.
With the "regular" criteria, it works without problem to have several times the same Criteria with different Values ("Layer" for example), but I can not figure out how to add multiple criteria for Library Part Parameters.
As soon as I add one of them, they become grayed out and I can not select them again.
Is there any way of duplicating these criteria?
0 REPLIES 0
