Yvonne
Annotations missing from schedules
Why do annotations (in plan/elevation views) disappear from schedules?
I have had this happen in a few different files.. sometimes the additional dimensions disappear and sometimes the notes.
How can I prevent this from happening again?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
11 Replies 11
Kornel Beleznai
Hi Mats,
Thank you for your question following up on this topic.
I discussed the situation with the developers and whether there are any recent improvements on it. They told me that the bugfix for this issue is quite difficult to execute, as the interaction between the two entirely separate functions (Schedule - Annotation) can come with deeper complications in the software.
Even though there is no target version for a permanent fix yet, this is an issue very much in development's sight and they are constantly working on a possible solution. Until that happens, the officially suggested approach is still the Cleanup disabling method through the Registry Editor that Minh described in details in his earlier entry.
I'm sorry for not being able to bring more progressive news and also for the inconveniences this problem might cause. Hopefully our developers will manage to come up with a solution as soon as possible. Until then, thank you for your patience!
Kind regards,
Kornél
Beleznai Kornél
Senior Technical Support Engineer
Mats Knutsson
Still need to do the regedit change in AC27?
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
