We value your input!
Apple switching to Intel..........Discuss
rm
This is going to hurt us at first on the Mac side. I hope in the long run, it means faster machines at lower prices with the rock solid stability of OS X.
http://www.macworld.com/news/2005/06/06/powerpcintel/index.php
...........discuss.
Oh, Windows people, try to contain the " I told you so comments " to a minimum
Robert Mariani
MARIANI design studio, PLLC
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
19 REPLIES 19
Aussie John
I dont think Archicad uses velocity engine(aka alti vec) or 64bite coding so that is something
Cheers John
[/size]
Thomas Holm
AA wrote:
here it is
http://www.pbs.org/cringely/pulpit/pulpit20050609.html
AHA! A conspiracy!
(... A classic AAitem, IMHO)
No offence meant. Gave me a good smile. Thanks, Albert!
TomWaltz
I bet you believe JFK's killer is still employed by the CIA too.....
Tom Waltz
It may be...
I bought (5) $35.00 Jul5 calls at $3.10
Thomas Holm
Seriously, read this:
http://www.nytimes.com/2005/06/11/technology/11apple.html?
(update)
And this:
http://arstechnica.com/columns/mac/mac-20050608.ars/1
stefan
No mention if the new Intel-based Macs will be able to run Windows and if the existing Intel-PC's will be able to run OSX.
I guess it doesn't really matter for the end user: he/she still has to decide between a Mac or a PC.
I do hope that the Mac's can benefit with some speed increasement, although we were all told that the G5 would deliver that 😉
And even now the Powerbook is still using a very old G4 chipset. Compare that to PC-portables, which have a choice between several chipsets. And the portable market is surely a big part of all computer sales, so they better migrate their laptops to newer processors too.
AFAIK, ArchiCAD is compiled on CodeWarrior for the Mac-version, so they would have to switch to XCode to do that and that means a port to the gcc compiler, which might be a bit of work. Or will XCode use the intel-compiler for all of this to work?
Archicad28/Revit2024/Rhino8/Solibri/Zoom
Archicad-user since 1998
my Archicad Book
Aussie John
the Macintels will probably be able to run windows-most likely via a hack. Virtual PC would run near full speed i imagine anyway.
Also they will use some sort of protection to allow OSX to run, so is unlikely any PC will be able to the same.
Cheers John
[/size]
From what I've read, Apple won't object to (or prevent) running Windows on the Intel Macs. They will prevent running the Mac OS on a non-Appple product though. I would guess that something like VirtualPC would still be preferable most of the time to avoid having to reboot to switch OS.
Thomas wrote:
AHA! A conspiracy!
(update)
And this:
This is worth a read as well.
http://daringfireball.net/2005/06/rule_the_galaxy
Short: Focus on your strengths, sub out everything else.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
