ArchiCAD MEP Modeler
Some time during this coming week, we can anticipate an announcement from Graphisoft concerning their new MEP Modeler for ArchiCAD.
Various people that you know from these forums have been beta testing it for some time, but of course have been sworn to secrecy. We've just been released from our non-disclosure.
So, I can start the 'leak' of information here. 😉
Personally, I have no real-world MEP experience, so my opinion doesn't carry a lot of weight compared to other people that you may hear from.
I'm really impressed with the MEP Modeler. It's fun to use and has quite a bit of intelligence. Routing and editing is easily done in 3D as well as 2D, and the various parts snap together intelligently...including smart connection 'ports' on both new MEP objects as well as related objects in the standard library (sinks, WCs, washer/dryer, furnace, etc). Touching elements can be treated as an assembly.
Conflicts with other building elements are easily highlighted with a Collision Detection feature that really works well and is cleverly integrated with the markup features of ArchiCAD. Only collisions between MEP elements and any other element are detected. (It is not a general-purpose collision detection feature: it will not detect a column that penetrates a floor, for example.)
The MEP Preferences let you pre-define the typical sizes and lengths used for ducts, pipes and cable carriers to make it easier to work with components that correspond to actual building elements.
The MEP Systems dialog lets you define the various systems to be used in your building and how elements in each system should appear. For example, ductwork is for air, but you can define systems for Cooling, Exhaust Air, Heating, Return Air, Recovery Air, etc as desired, all of which would use ductwork, but might display themselves with different pens, materials or line styles - and which would be selectable as systems.
There are a couple of unique work methods, but nothing big - just have to learn it. For example, if you select multiple MEP elements and want to modify them together, you cannot use the Object Settings dialog or Edit Selection Set, instead there is an Edit Selected Elements dialog. But, since that dialog is customized for MEP, it is actually cleaner, once you are used to it.
There are new pet palette options for editing, and there is a connection library part that one can assemble along with other AC elements and save a custom MEP part with smart ports without programming in GDL. For example, if you needed a floor grate for a conditioned air system, you could create it with tiny walls or beams (etc), place the connection object as desired under it, and save the bits as a new lib part. When you route ductwork to this floor grate, it will snap to the port.
This is just a way-cool and long-awaited addition to ArchiCAD.
I have no information on pricing, etc.... so am staying tuned for the announcement like everyone else. We're told that a WIBU protection keyplug is required to run the MEP Modeler within ArchiCAD: it can be either the same keyplug that has your ArchiCAD license, or a separate one.
PS There is also a new plug-in for AutoCAD MEP 2008 and 2009 that allows you to export AutoCAD MEP systems into ArchiCAD via IFC. I did not test this, so can't offer any comments.
PPS I do not receive any compensation from Graphisoft for this post or any of my time/work on these forums or the wiki.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.9, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
63 REPLIES 63
Thanks for the detailed information Karl, much appreciated, especially since all this work is pro bono as far as GS is concerened.
I did dabble a bit with Vico constructor a couple of months ago, just to use the MEP module included there, but I was dissappointed because it gave the impression of being pre-beta. One of my pet peeves with that was it would would only offer imperial sizes. Can you confirm that this module will be metric too?
Thanks again.
Thanks.
The AC MEP Modeler is either imperial or metric, picking up units as per preferences. The beta version was INT, and installed with metric defaults in fact. I switched to Imperial, redefined sizes under MEP Preferences, and worked normally there as well.
I have no experience/knowledge of whatever might have been bundled with Vico, but the new AC MEP Modeler felt robust at its last beta - ready to work with. Of course, I know of various 'wishes' (when will we not want more?) - and once released, it will be interesting to see how many of those are echoed by users.
Please told us any info about pricing, demo version, and avilablity in countries.
Thanks.
Graphisoft will provide that information when they make their official announcement. Only they know these details.
TomWaltz
The last time I had seen it, it looked pretty cool. One guy on our team commented that the duct tools would make really good stair railings.
Tom Waltz
Erika Epstein
The MEP Beta was everything Karl said it was. Even the manual was extremely well written.
The MEP modeler was so easy to use and for the most part intuitive as to how to use it. The graphic ease working in both 2D and 3D with which you could create, edit and check for clashes was impressive. The interface for editing was unusual but easy. Adding or moving intersection points or shifting a length of parallel segments is akin to editing a slab/roof/mesh/polyline.Sounds odd, but so easy.
I tested it on a restaurant, house and hospital. I too work in Imperial, not metric, so first switched the files accordingly. The hospital's many MEP systems were easy to replicate and coordinate. Connecting the systems from floor to floor was literally a 'snap' with the embedded smart snap hotspot at the ends of each MEP element.You can also create custom MEP library parts. If you embed the included special MEP library connector part, your custom parts will behave like the the included ones and 'snap' together.
I am an architect, not an MEP engineer. I tested it by replicating systems from MEP consultant drawings. Typically, as many architects do, I have routinely crudely model MEP as well as structural systems in my projects to insure adequate space and to resolve coordination during design not construction. The MEP modeler does this much faster,more accurately and efficiently. Have I mentioned how QUICK & EASY it is to use? This gave me realistic sections, elevations, RCP etc. and in so little time. The result is better coordination of disciplines. Incorporating and working with the various MEP systems with this modeler aids our designs, instead of fight it.
It was almost too much fun playing with it. I hope a similar structural add-on will be forthcoming.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Dwight
Erika: So it would make stair railings that climb?
Dwight Atkinson
TomWaltz
Is there another kind of stair?
Tom Waltz
Dwight
Just making sure… punk.
Wouldn't want the imagination to get carried away without the harsh and potentially disappointing reality of an explanation from someone who was there.
SO: please confirm that i could make a proper and real handrail.
Dwight Atkinson
