ArchiCAD-Tekla Structures Interoperability Guide
Here is another PDF document about ArchiCAD-Tekla Structures Interoperability:
http://download.graphisoft.com/ftp/pdf/InteroperabilityAC15.pdf
(Note: the original link was not available anymore, hence the other posts in this thread, now the correct link is shown in this first post.)
9 REPLIES 9
Wrong link. That is the revit guide from the other post. It would be great if these links were easy to find on Graphisofts main website.
Oops. Sorry.
I corrected the link in my first post.
Thanks.
There was also a webinar recently that discussed the Tekla-ArchiCAD workflow using the same building example as in the PDF.
http://www.tekla.com/international/solutions/building-construction/Pages/wednesdaywebinarcampaign.aspx
ratnabhirud
All above links are not working.
Is there any other link for IFC export from Archicad14/15 to Tekla Structures17?
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
I have found this:
This is a more general guide but also contains steps for the Model Exchange Workflow for several Structural Applications including Tekla.
I suppose with the introduction of the IFC Translation Dialog this PDF had to be rewritten, this is why there is this new PDF.
ratnabhirud
Thank you very much Laszlonagy for your help.
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
Ernest Atanasiu
Is there an updated version for 18?
I am trying to convince our subcontractors to adopt a 3D and possibly BIM workflow and I need strong convincing arguments.
Thank you.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 10/ Win 11
Here is a link to the entire ArchiCAD 18 collaboration guide:
http://helpcenter.graphisoft.com/guides/archicad-18-collaboration-guide/
From the right hand side navigation list you can get to the most appropriate sections for your needs.
Jared Banks, AIA
Shoegnome Architects
Ernest Atanasiu
Thank you!
