2021-05-19 11:43 AM - last edited on 2022-09-22 06:07 PM by Oleksandra Vakariuk
Solved! Go to Solution.
2024-03-30 08:53 AM
hello @Martin Jules, thank you for responding, where can I find the word document?
Thank you
2024-03-30 09:01 AM - edited 2024-03-30 09:07 AM
Use the right click of your mouse, through the contextual menu, to open the existing manual with Microsoft word.
2024-03-30 04:40 PM
@Martin Jules @Podolsky Good Day, is there a different method of disabling the License on Windows, I have tried the above-mentioned way, but the objects have remained locked.
2024-04-09 09:56 PM
Hi Alexey,
Thank you a lot for your contribution! I am very impressed of your work.
I got an error when "BRACKETS" checkbox enabled in the bIM Soil Pipe object settings: "Invalid 3D symbol. Open the library part for editing and check 3D script for errors". As far as I can see in a 3D script there is a macro call "Pipe Bracket Macro" which is not present anywhere in the library and this issue cause the error. Could you please upload this script so I could fix the object?
2024-04-10 03:29 AM
You may get a response, but don't expect one.
Alexey (Podolsky) has not been on-line here since August last year.
2024-06-20 09:44 AM
I have been using the template and library for ages and love it!
Recently however, we have had a problem with it. When a point cloud LCF is added to the project, the template stops working and all sections, elevations and title blocks etc turn into black dots! When the point cloud is removed, it works again! This started happening since about December 2023, fine before then. I'm using AC24 Solo on Windows.
I did wonder if it had to do with the TLS 1.2 update which Graphisoft released in Nov 2023, so when I re-installed AC to check that, I tried it without that update and it still happens. I also re-downloaded Podolsky's files and re-did the licence hack, so the only thing that has changed in the environment is Windows itself. This happens on two other PCs of mine.
Anyone have the same problem or any idea what is causing it? Even better if there's a solution out there?
2024-08-16 06:19 AM
i need rrooofmaker to download
Monday
Hello everyone!
Huge thank you to @Podolsky !!!
Did anyone discover how to change the logo in the title block library?
I am slowly going through all the library and templates.
Looks amazing!!
