ArchiCAD drawing to MIcrostation DGN (Version 7 or 8)
Dear ArchiCAD Support,
Can we perform conversions of ArchiCAD drawing to MIcrostation DGN (Version 7 or
Eduardo Rolon
You can save to DGN though you cannot specify which version. I would assume that at a minimum it should be the years prior, AC21 came out in 2017 so it should support Microstation version that came out in 2016.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
vistasp
Hi Bireshwar, although hosted by GRAPHISOFT, this is a user group -- not an official support forum.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
MicroStation has been on version 8 for a very, very long time. Archicad will not save or import V8. It will only work with V7. I tried saving my V8 files down to V7 to import them. The result was very disappointing. It was a little better when they were converted to dwg.
It really is a shame that Graphisoft ignores the next best BIM software on the market. There are many things AECOSIM Building Designer does better than Archicad.
