ArchiCad 15 dwg into SketchUp?
I hope this topic is not too far out of place in here. tips and ricks was closed.
I am trying to get a vector/line based (like a dwg) import out of AC and into sketchup.
without downloading and paying for a full pro version, or working in the 8 hour time frame, does anyone have a work around for exporting a dwg (or something) and getting it into sketchup? a pdf comes in as an image, and havent seen a place to export a 3ds file.
any help would be greatly appreciated!
TMA_80
Try to find an older free version of Sketchup ( version 7 or earlier, as those versions had a native dwg support )
AC12_20 |Win10_64bit|
Are you sure?
I thought none of the free versions ever supported any formats aside from skp and kmz. I've been using the pro version since 5 or 6 so I might have missed something.
TMA_80
Hi Matthew,
That's how it worked.
There was a native dwg support till the 7 th free version of sketchup ( file /import ). In the 7.1th version, this was still possible but through a separate plugin.
From the 8th version of Sketchup, the dwg support in its free version has stopped.
http://sketchupdate.blogspot.com/2009/08/coming-soon-in-google-sketchup.html
There are however, as an alternative, some ruby scripts for the free version that can import and export the dxf fromat.
