Dalius
ArchiGlazing for ArchiCAD 18???
Hello, I'm an ArchiCAD teacher at Vilnius Academy of Arts. Can somebody answer me, what's happened with ArchiGlazing for ArchiCAD 18? It was one of the most useful tools by architectural students making their projects. It was so easy to create custom shape windows, slanted glass structures, winter gardens, etc.
What should I answer to desperate students? What are the Graphisoft's plans?
Dalius Regelskis
Archicad user since version 6.0
https://archicad-pamokos.lt
7 Replies 7
Here is the Graphisoft page about ArchiGlazing:
http://www.graphisoft.com/downloads/addons/archiglazing/
At the bottom it says:
* ArchiGlazing is an Add-On for ArchiCAD that are based on legacy code which GRAPHISOFT does not support anymore. You can use it 'as is', but be warned that they might not function properly, and they will not be fixed or upgraded.
* ArchiGlazing can only run if ArchiCAD has been properly installed on your computer.
* The system and hardware requirements correspond to those of the ArchiCAD version: http://www.graphisoft.com/support/system_requirements/
* Available from ArchiCAD resellers worldwide.
So you should contact your reseller to obtain it.
Dalius
Laszlo, the local reseller says, that there is no ArchiGlazing for AC18 on GSPartner Site, as it was with earlier AC versions. So the question remains unclear.
Dalius Regelskis
That is interesting because for example, the French distributor has download links in its site for the French version of ArchiGlazing 18:
http://www.abvent.com/support/download/index_soft.php?id_pro=1&site=fr
I am wondering whether this is something that is now available only on selected markets.
RandyC
Apparently it is no longer available in Canada either - my reseller has
never got back to me after I made the same request
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
PB
ArchiGlazing 19 available from the french ArchiCAD site:
http://archicad.fr/support/telechargements-archicad-19/
Hope this helps...(I've not tried it yet, although I used it a number of years back)
AC29. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 26 Tahoe
Hi, any news about Archiglazing? is not available anymore, I will like to get a demo, but I can't find where to download it in english. Thanks!
