2015-02-04 02:11 PM
2015-02-04 04:58 PM
* ArchiGlazing is an Add-On for ArchiCAD that are based on legacy code which GRAPHISOFT does not support anymore. You can use it 'as is', but be warned that they might not function properly, and they will not be fixed or upgraded.So you should contact your reseller to obtain it.
* ArchiGlazing can only run if ArchiCAD has been properly installed on your computer.
* The system and hardware requirements correspond to those of the ArchiCAD version: http://www.graphisoft.com/support/system_requirements/
* Available from ArchiCAD resellers worldwide.
2015-02-05 12:13 AM
laszlonagy wrote:Laszlo, the local reseller says, that there is no ArchiGlazing for AC18 on GSPartner Site, as it was with earlier AC versions. So the question remains unclear.
2015-02-08 01:47 PM
2015-02-08 07:13 PM
2015-11-05 03:38 PM
2015-12-09 07:55 AM
2016-06-15 04:01 PM
