Dear friends I just upload the latest ArchiStair maintenance release (1.08) both for ArchiCAD 8.1 and ArchiCAD 9.
In this latest version I just added two features requested by some of you:
1. a smarter numbering orientation for the 2D symbol (please, look at the previous post in this same thread)
2. a better usability thanks to the 2D hotpots along the stringers perimeter
About the first issue, Iām going to explain you how it works.
1. Enable the tread numbering as before.
2. The numbering orientation follow now smarter rules
As oreopoulos suggested, if you are displaying only the numbers (and not the levels) you can also do something else:
1. select the stair
2. double-click on the Stair tool icon in the ArchiCAD palette
3. in the ArchiStair object parameter you can enable the ānumbering fixed angleā parameter and use the below variable (ānumbering angleā) to define the angle the numbering texts will follow
Hoping this will satisfied you,
Friendly
Fabrizio
P.S. as usual, if you are ArchiCAD 9 users you can also use the ArchiStair update comman (directly from the ArchiCAD Extras menu) to download this update.
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
