ArchiTerra
Hi!
I installed ArchiTerra demo, is there a way to make it so it won't make the ArchiTerra layers when created a new project? Or do I have to erase ArchiTerra from my Add-ons folder?
4 REPLIES 4
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
That layer is a "service layer" and it's created any time ArchiTerra starts.
ArchiTerra is a pre-loaded add-on so the layer is always created.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Ok, thanks!
Another question, I try to import an .dxf file, it's a normal file where polygons have z-values.
But ArchiTerra can't import this file?
I open it in ArchiCad (which make z-value in lines dissapear), and save as .dxf then i got all heightlevels in ArchiTerra, BUT (there's always a but) ofcause there is no height anymore.
What type of DXF files should it be that ArchiTerra can handle?
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
DXF files including compatible entities (look at the ArchiTerra user manual for further info) with 3D info.
If the levels are simply "written" (I mean the level is showed in a text) or are blocks entities (block are like the AC objects) ArchiTerra cannot import them.
Maybe if you could privately send me this DXF file I can check it and be more useful for you.
Friendly
Fabrizio
Fabrizio Diodati
Mail somewhere out there adressed to you!
