Architerra3 road
When i create a ROAD and then try to delete it by selecting the ROAD AT3 object and clicking DELETE, there is a light grey image of the ROAD object that remains on the drawing that cannot be selected. How is this graphic element selected and then deleted?
4 Replies 4
Link
Sounds like you may have a trace reference of the same story you're on. Try rebuilding the reference and see if it disappears.
You'll need to do that via your Trace & Reference palette. Or you could do a Rebuild & Regenerate (Ctrl+Alt+Shift+R). Or the equivalent keyboard shortcut for a Mac - either way, it's a real finger snapper.
Link.
The trace reference is one of the first things I checked before posting the issue > it isn't the trac; the lines are grey and my trace ref is light blue and rebuilding trace does nothing.
Thanks for trying though.
Link
Sure. Well I guess I will leave it for Fabrizio or someone who uses ArchiTerra.
Good luck.
Link.
i thought i found the solution > which was to use the Data Update tool. after i selected the mesh and did an UPDATE, the image went away. good.
but after closing the file and reopening it a little later, the old road image was back!
oh well.
