ā2005-10-16 11:56 AM
ā2005-10-17 05:57 AM
oreopoulos wrote:It is a completely different software solution for completely different purpose. Maybe the same ArchiCAD engine is used, but the similarity ends there ...
My worries come from the fact that if AC10 has the calculation features it should, then why should Graphisoft Constructor exist?
ā2005-10-17 02:50 PM
oreopoulos wrote:
As time appoaches for AC10 (isnt it?) i really wonder if we are going to see improvements in the calculation side of AC.
I use the database a lot, but i find that it has been left behind in development.
ā2005-10-17 03:53 PM
ā2005-10-18 06:33 AM
oreopoulos wrote:The problem is: how many architects model the reinforcement in their reinforced concrete? What is the level of the detail in your model? I don't mean 2D detail, fully modeled details?
Sorry Djordje but reading all the turorial of Constructor, i am sure that its the same excacly product + a few addons + notion of recipe
ā2005-10-18 09:09 AM
ā2005-10-21 03:59 AM
ā2006-03-05 12:43 AM
Djordje wrote:I am a home builder and I am a fanatic when it comes to accurate plans and the ability to take advantage of creating an accurate model that results in automatically accurate schedules.oreopoulos wrote:The problem is: how many architects model the reinforcement in their reinforced concrete? What is the level of the detail in your model? I don't mean 2D detail, fully modeled details?
The architectural practice in Europe does go for far more detailed approach than elsewhere, IMHE. I understand what are you saying - and it would be good to enrich the ArchiCAD package ("for architects") with the Constructor functionality you talk about ("for builders"). Frankly, most of my professional career I was in the design and build orianted companies - because, you can't charge enough for the design, and you can control the build properly only if you designed it yourself.
If the user feedback to Graphisoft is strong enough, and documented enough, there might be results. Whining never helps.
Then again - think about your colleagues. How many of them understand that the intelligent 3D model is the right way to go? How many contractors/builders treat your approved construction documents as something more than to spread on the site table to have the lunch on? How many of them will even consider investing into a software?
Quite a mountain to climb ...
