Mario Sacco
Archicad 14 Layout to Autocad Paper space lost border path
In AC 14 3269 - I have placed a view (1) on Layout, changed the path of the border of the drawing (2). When I export in dwg (3), with set "paper space with views full contents" I lost the changed path of the border in Autocad (4) paper space. Wath I'm working? In AC13 it worked right well.
Mario
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
4 Replies 4
What happens if you set "Paper Space with Cropped View's Content" in the Save Layout Into field?
Mario Sacco
The same result with "Paper Space with Cropped View's Content".
It works only with "Paper space with drawings as block", but I lost dimensions and everything is esploded.
And you are saying that in ArchiCAD 13 it was working fine?
In that case I would say it is lost functionality and you should report it.
Mario Sacco
yes, I have tested right now with AC 13 and it works fine. I thought I was wronging something. I'll report it.
Thank you
