Check your DWG Translator settings under File->Interoperability to see if the Autocad version you are saving to is correct. Recommendation is to set it to an older version of Autocad (like 2004) to avoid compatibility errors
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08Macbook Pro M1 Max 64GB ram, OS X 10.XX latest
another Moderator
