MDunkin
Archicad 28.0.2 DWG import function missing
Anyone using version 28 experiencing the inability to drag and drop a dwg or add it via. file/external content/place external drawing?
When you go the file/ex route and look at the available file formats .dwg is gone.
    Operating system used: Windows 28.0.2 USA Version 3110
AC28: Win10 Pro, 12th Gen Intel(R) Core(TM) i9-12900K 128gb ram, RTX-A6000
1 Solution
MDunkin
Hi Laszlo,
I had to do a re-install with a fresh download to get it fixed.
Go to post
5 Replies 5
Does not seems to be the same dialog for the place external drawings formats, here is what I get in AC 28.0.2 Mac:
www.graphisoft.com/en-gb/partner-solutions/airc-digital-openbim-services/ co-founder /Operations Director /BIM Lead @ www.airc.digital ltd ™
M Architecture & Urbanism
Archicad 29 ARM, MacBook Pro M3 Max 128Gb, macOS Tahoe.
Are you using the full commercial versions of Archicad, or the Start/Solo version?
I just looked at my options when I place a drawing and I see this.
@MDunkin,
If you go to the Options > Add-On Manager Dialog, do you see the DWG/DXF Input/Output Add-On listed?
Is there a checkmark next to its name in the Load column? That indicates that the Add-On is loaded into Archicad properly.
MDunkin
Hi Laszlo,
OK, great, so it was resolved.
