Archicad-3ds max compatibility
Hello everybody!
I just joined the forum, and I 'm a new user of Archicad, working currently with version 8.0. You may find my question really simple-minded, but you 'd help me if you let me know whether you can export objects made with 3D studio max into ArchiCAD and vice-versa.
I think it would be difficult to model things like, say, hypars on Archicad, and modelling them on 3Ds and then exporting them could save (me) time and trouble. I also think it would be cool to build a model on Archicad and be able to render it on 3Ds, although this seems to be less needed, since as I learn, Archicad 's new release 9 has a very good rendering engine.
Dennis
10 Replies 10
Erika Epstein
in form z save as .3ds file type.
In archicad, under Extras, choose "Import 3D studio " option and it will bring it in. In the help menu it reviews some of the options available.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Ben Odonnell
Unfortunately in ArchiCAD 8.0 the import 3ds add-on is not available right out of the box.
There is a link floating around here to the German GS site which has a version of the add-on. If I remember correctly it is to ArchiCAD 8, but I could be wrong?
I can't remember if it was done for ArchiCAD 8.0, but as I said there is a link on this forum right to it, so if you do a search it should bring up some results for you.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Erika Epstein
oops
didn't see the 8.0s
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
stefan
Export : use *.3ds
Import : use *.3ds
See attachments...
(I did not make any of this. But it was freeware.)
3ds Import for AC7
(includes PC + Mac + 6.5 version)
Archicad-user since 1998
my Archicad Book
stefan
3ds import for AC8 (PC + MAC)
my Archicad Book
stefan
3ds import for AC8.1 (PC-only)
my Archicad Book
May be exist so program which can export ArhiCad project into 3D maks
for creating from here flash on Web need which differ from original representation
stefan
I have a problem understanding the question... but let's try...
If you want to have an ArchiCAD model as a Flash-animation, then you could export the ArchiCAD model into *.3ds or *.dxf and open it in:
- 3ds max and using the Illustrate or Vecta3D or Swift3D plugin export it into a Flash-image or animation.
- XSI, Maya or Lightwave and using the Swift3D plugin to export to Flash
- the standalone version of Swift3D and export to Flash.
But, Swift3D, Illustrate and Vecta3D are not included by default in these applications and they are not free.
my Archicad Book
Sorry for my english
to begin i forgot say - that all for ArchiCad7.0
and I should say next:
export the ArchiCAD model into *.3ds or *.dxf and open it in Maya.
Thank you ...
