Archicad export to Autocad text problem
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-03-02 10:32 AM
‎2021-03-02
10:32 AM
Labels:
- Labels:
Data Exchange
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-03-03 09:52 PM
‎2021-03-03
09:52 PM
Hello mervelousss,
Do you have configured the font match into dxf/dwg translator ?
Or are you sure that autocad has access to the font used by archicad ?
Did you link the SHX file with DWG file ?
The SHX format supports various Type 1 PostScript fonts and can also be used to store fonts and small building blocks that are usually inserted in drawings.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-04-09 03:39 PM
‎2021-04-09
03:39 PM
We have several different PCs with Archicad installed on Windows
separated licences
same versions
all updates (Archicad + Windows) up to date
pln or TW...
Problem:
After we export the same data to dwg with the same export filter - The result is different text (for example Roboto)
Example:
Picture 1 - Incorrect output
Picture 2 - Correct output
separated licences
same versions
pln or TW...
Problem:
Example:
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-04-09 09:15 PM
‎2021-04-09
09:15 PM
you need a couple of things:
a) a copy of the default Autocad template file called acad.dwt
b) add this to your preferred translator in the Save options (see screenshot)
c) create a font-style conversion table with one item for each font in your file (see 2nd screenshot).
The file I grabbed converts our preferred font to Arial and gets rid of the acad stick font.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-6000 USA
Rhino 8 Mac
MacOS 14.6.1
Rhino 8 Mac
MacOS 14.6.1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-08-09 02:04 PM
‎2021-08-09
02:04 PM
Good day, the problem persists. I know the function using template from autocad, but it doesn't work. If I use font Roboto for example, then it doesn't work. We have 11 computers in the office. On 1 pc it works and on others it generates bad dwg (variant without autocad template too).
