Archicad16 to Sketchup 8 .skp export
Hello and thanks in advance,
Im currently trying to use the style builder within sketchup using my AC model using the google earth connection add on. The export works great however whenever I try to turn on a line style within sketchup nothing is shown. I can still select the faces but there are no edges to speak of. Has anyone encountered this before? I have edges turned on.
Regards,
Matt
1 Reply 1
Problem solved via Sketchup forum. Hidden geometry was turned off, turning it on showed that edges were there but hidden. Unhide all then revealed all hidden geometry including the edges.
