Wall dimensions in IFCxml exported from ArchiCAD 16 Hotfix 2
Hello dear all,
I would like to kindly ask you for support, regarding iFC(xml) export from ArchiCAD 16 (Hotfix2) of WALL elements:
For example we have a wall with the following settings:
• Length = 11.00m
• Height = 3.00m
• Thickness = 1.0m
• Position of element (Wall Selection Settings > Tags & Categories) = Exterior
• Translator settings – please check attached files. The translator is set up, according to Graphisoft's guidelines in this direction
In iFC(xml) formats the area of the wall should be: 33.00 m2 and the Length = 11.00m (and volume = 33.00m3) , but the area appears as 30.00 m2 and the Length = 10.00m (and volume = 30.00 m3), because the Export always takes the axe (middle line of wall) as a wall Length during the export!
Can you help me to Export the same wall, so in iFC(xml) format the wall area appears as BRUTT: 33.00 m2 and the length appears also as brutt (exterior) = 11.00 m?
Thank you in advance for your support!
3 REPLIES 3
here is the IFCxml file produced
and here are attached screenshots with IFC translator settings
The values of IFC translation are OK, becose the walls reference lines are in the midle and there are 2 walls in the corners! (the outer lenght is 11m, but the inner lenght is 9m; the mid value is 10m!).
Maybe there must be 2 calculated surfaces (outer= 33m2, and inner=27m2).
Try to move the referene lines on the outside surfaces to obtain yours values.
