Problems with Sketchup Add-on
Somehow I can't get the Sketchup Add-on to work...
I downloaded the add-on and have put it in the AC16 Add-on folder.
Then used add-on manager to load the add-on, but when I try to open a .skp file (surroundings of my project) in AC16 I get an error saying that the SKpIOApp.exe can not be found in the main AC16 folder...
Does anyone recognize this problem? When I put the .exe in the main folder I don't get the error, but another error that there is something wrong with the .skp file. So I don't think that would be the right solution.
I really want this to work, otherwise I will a lot of time making the surroundings again in AC.
Thanks in advance.
vistasp
Mentor
Michiel, what file did you put in the addon folder? AFAIK, the Google Earth Connections addon is downloaded as an installer.
http://www.graphisoft.com/products/archicad/addons/google_earth/ge_earth_connections_download.html
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
