Problems with Sketchup Add-on
Somehow I can't get the Sketchup Add-on to work...
I downloaded the add-on and have put it in the AC16 Add-on folder.
Then used add-on manager to load the add-on, but when I try to open a .skp file (surroundings of my project) in AC16 I get an error saying that the SKpIOApp.exe can not be found in the main AC16 folder...
Does anyone recognize this problem? When I put the .exe in the main folder I don't get the error, but another error that there is something wrong with the .skp file. So I don't think that would be the right solution.
I really want this to work, otherwise I will a lot of time making the surroundings again in AC.
Thanks in advance.
1 REPLY 1
vistasp
Michiel, what file did you put in the addon folder? AFAIK, the Google Earth Connections addon is downloaded as an installer.
http://www.graphisoft.com/products/archicad/addons/google_earth/ge_earth_connections_download.html
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
