‎2010-04-06 11:24 AM
‎2010-04-16 04:22 PM
‎2010-04-16 07:04 PM
Braza wrote:
Sorry Gemito for hijacking your thread a little.![]()
So... It seems that ZoomGDL was more like a rudimentary GDL graphical editor. I have the impression that if it could have the opportunity to evolve it would certainly become something like the actual Grasshopper.![]()
Anyway... Its never too late to catch old ideas and use them in new ones.
By the quality of this application at that time (2003) I'm pretty sure that Graphisoft team is highly capable to develop something even more revolutionary.
‎2010-04-17 03:22 AM
‎2010-04-19 08:40 AM
lec1212 wrote:yes . . . that program was made by abvent and they stoped developing it. If you try to work now in zoomgdl you will realise that UI is so old and clamsy and its so hard to draw acually there.
Hi Necko
I'm curious about your zoom gdl 2.1
Was that by Artlantis?
Seems like it's still available for around $30us.
here:http://www.soking.us/soft/Product/Pro515.Html
Does that seem correct?
Much thanks.
lec
‎2010-04-20 12:12 PM
‎2010-04-20 07:58 PM
lec1212 wrote:As Necko said it was made by Abvent.
‎2010-04-21 02:42 AM
gemito138 wrote:An ArchiForma object is just an object, like any other. ArchiCAD can only insert windows and doors into Wall elements, not objects that look like walls. There are some crazy tricks you can use to combine a window in an invisible wall with other elements and save the assembly as an object ... but the window will not be schedulable - it will just be part of the objects mass.
Yesterday I received the dongle of archiforma...
Is it possible to insert windows in an archiforma object?
‎2010-04-21 03:29 PM
Karl wrote:I have a video of this trick
‎2010-04-25 11:35 AM
Karl wrote:How? i have made wall with the same size of the window and then subtraction them, but in plants it doesn't appear. I made a 3d view with parallels view and then i made a 3d cutaway...gemito138 wrote:An ArchiForma object is just an object, like any other. ArchiCAD can only insert windows and doors into Wall elements, not objects that look like walls. There are some crazy tricks you can use to combine a window in an invisible wall with other elements and save the assembly as an object ... but the window will not be schedulable - it will just be part of the objects mass.
‎2010-04-27 05:07 AM
