Architerra Export Points with Point Ids
Another problem I am facing with, in my endeavor with architerra, is
that I need to export the points of the mesh including the point id.
At the moment I can export the coordinates but without the pt id.
Does anyone know if this is possible or if there is a workaround to it?
1 REPLY 1
wow, over 200 views and no reply,
so either I found a critical feature missing or not many people are facing the problem of exporting the points for contstructions purposes.
