B.O.Q
hi to every one
this is rose thomas from MUMBAI ,India
i have been making ......rather trying to make A set of B.O.Q. which has a format in excel file ......... i want this same excel format file to be transferred or imported to archicad .
As i see it i have three parts ....in which i can feed in my data ie the writeup 1. Data base
2. you assign property
3. link these properties to your drawings
but this above process has its default settings ie a default format in excel .......i want to customize it ....
CAn any one help me out with this small problem
14 REPLIES 14
here is a copy of the format i want
vistasp
Jolly, I think you wanted to post this in another thread that you started. In any case, there's no attachment. Use the "Add an Attachment" part of the posting form and preview your messages before you submit.
Also, it would be helpful if you insert your Archicad version and operating system in your signature. That will help others help you.
Cheers.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
(I've merged the two threads ... but yes, we need the attachment. The original question does not really make sense to me.)
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
We prepare Tender Documents in Excel format.We want the same format in AC12........it can be in *text also
The Excel format is attached with this mail
Can it be done?
Jolly,
This is the second time that you have started a new thread instead of replying to the thread that you already started. Please be careful and REPLY to this thread for issues related to your schedules. Only start a new topic if it is an entirely new topic, OK?
Once again, I have merged your posts.
Thanks,
Sorry again. i will do that. but currently i cannot see the reply ppl have posted . i can only see yours.
JOlly
Jolly,
After looking at your spreadsheet, I believe the most efficient thing for you to do is to purchase a copy of Eric Wilk's book "ArchiCAD From CAD to Quantity Survey" which will explain how to import your Excel information into a database and then to use that to extract the model information you need.
The book is available in French or English for 40 euro direct from the author in France here:
http://www.boutique-fc-cadlink.com/fccllfr001-p-28.html
and may be available from other resellers such as Cad Garage (US):
http://www.cadgarage.com/arfrcadtoqus.html
or perhaps someone closer to you.
JOlly
That's because nobody else has replied. 😉 This is not a topic that will get many replies as only a handful of people do BOQ.
hey thanks for being patient. can u please tell me why is it that i am not able to view the other reply that has come to me .......
