Hello List :
I've created a test database in AC13.
DB Name
General
Insulation
300 mm FG, qty 1 m2
Panel skins
18 mm OSB, qty 1 m2
10 mm OSB, qty 1 m2
Stringers
#1 joist, qty 1,6 m2
Units
m
m2
m3
pc
I've created a property : testPanel
DB Name Key Code Name Qty Unit Proportion
name 003 005 1,8 mm OSB 1 m2 Surface A
name 004 006 #1 joist 1,6 m2 Surface A
name 002 009 100 mm FG 1 m2 Surface A
name 003 008 1,0 mm OSB 1 m2 Surface A
and assigned the following to a slab :
However, the BOM for a 1 x 1 m test panel shows :
1 m2 for 1,8 OSB
but 2 m2 for 1,0 mm OSB.
If I set the quantity of 1,0 mm OSB to 0,5 it lists correctly as 1 m2
What am I missing here?
Regards : Hubert Wagner
