Broken Images in Certified Archicad BIM User quiz
Kikoria
Hello. I wanted to become a Certified Archicad BIM User by taking quizzes of the different topics in Archicad. From the beginning it was really cool. I got from 90% to 100% range scores but when I took another quiz it had photos attached in questions but the photos were broken and I couldn't see the content of it. So I couldn't answer those questions with broken photos and I had to randomly select the answer in order to move forward. The images looked like this:
So, finally I couldn't pass the quizzes that had broken photos in it. Could someone please help me to solve this problem or is it a site problem? I tried to change the browser. I tried Google Chrome and Microsoft Edge but the broken images remain broken. Thanks in advance!
Kind regards,
Tamaz Kikoria
Architect
Technical Examination and Design Department
GEORGIAN WATER & POWER
2 ACCEPTED SOLUTIONS
I am not 100% sure if this will work, but try your browser in 'private' mode so it does not use site cookies.
There has been an issue with some Graphisoft sites and cookies stored in the browser.
The other option that may work is to clear all cookies associated with Graphisoft.
Akos Karoczkai
Dear Kikora,
Indeed we experienced some issues with Graphisoft sites. Clearing the browser cache and cookies should solve the problem as Barry mentioned. If this or logging in via a private/incognito browser window does not solve the problem, please reach out to us at learn@graphisoft.com!
Thank you,
Akos Karoczkai
Manager, Professional Services, Customer Success, Graphisoft
Ákos Karóczkai
Senior Manager, Content and Team Operations, Learning Excellence and Innovation
4 REPLIES 4
Akos Karoczkai
Dear Kikora,
Thank you,
Akos Karoczkai
Ákos Karóczkai
I think that makes sense. I will try. Thank you.
Kind regards,
Tamaz Kikoria
Architect
Many thanks for your help! The incognito mode solved it!
Kind regards,
Tamaz Kikoria
Architect
