Cadimage - Design Suite
Hey all, I was trying to install the Cadimage Design Suite add-on to my ArchiCAD 13 Student Version (64bit). When installing, the Cadimage installer 'searches' for the Graphisoft folder for a while. It never does find it on its own. I don't have the option to select a folder either. After I cancel the install and start it again, it goes through no problem.
I then go to open up ArchiCAD and get all kinds of errors about the master script, things missing, etc. I didn't screenshot any of it, but if needed I can go through the procedure to show you exactly what is going on. Is anyone else having this problem with the add-on?
5 Replies 5
Brett Brown
You might get answers to your problems here, if not email them on Monday
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
ci-JoshOs
yep, just log a new support ticket with us here:
http://www.cadimagetools.com/resources/support.aspx
it sounds like it might be a permissions error of some sort...
Josh Osborne - Central Innovation
Mac Mini
I am in the same situation as you R_Gautschi. same story. I also have Achicad 13 64 bit installed. all was working until CADIMAGE came along. full of errors. I followed the installation instructions. i tripled check by uninstalling achicad. so the problem comes with CADIMAGE. zzz >.<
Someone help us.
It works tottaly fine with 32bit system.
Is there a Cadimage 64bit installation i dont think there is.
If you have found a solution please massage me thanks
ci-JoshOs
Have you logged a support ticket or emailed yet?
If you want help from the Cadimage Tools Tech Support people, that's what you need to do. The link to the support system is above, or you can just email [email protected]
They will need more information than you've put into your post too, so please let them know what the problem is specifically and include screenshots if possible.
And no, I won't 'massage' you. Sorry.
Mac Mini
Oh come on, you're not too far away and it may be fun.
