Cadimage door curve resolution
Good evening.
Cadimage door and windows, for the life of me I can't find where to change the 3d/elevation curve resolution for an arch top door. If someone could point me in the right direction that would be great.
Thanks
Jim
3 Replies 3
ci-JoshOs
Hi
We don't currently have a way of doing that.
Could you give a bit more detail as to why you need it changed though? The arc resolution is already fairly high in the object, so I'm curious about what you need to increase it for.
Josh Osborne - Central Innovation
Mac Mini
Thanks for the response.
See attached elevation view. The line segments are pretty large, which is why I would like to decrease those line segments.
Thanks again,
Jim
ci-JoshOs
Oh right - that's a big 'un!
I've tried drawing up something that looks similar to your, and it gives me a nice smooth curve.
Could you send me a Module or PLN file showing the problem so I can look into it a bit deeper?
Mac Mini
