Cadimage file not found ?
I've just installed Cadimage and attempted the wall accesories, but I get the following message :
I've searched here for 'cadimage' but the only thread I found didn't help me.
Thank You
11 Replies 11
I contacted Cadimage when the problem happened, they have responded :
" When you choose the Wall Builder accessory object, the error message
pops up because you don't have a fill of that index loaded. This is an
unfortunate ongoing issue with ArchiCAD, but there is a fairly simple
work-around. In the settings dialog, navigate to Appearance > Floor Plan
and use the field to select an available fill "
I still have a few problems, but it works now
I had the same error occur the helpfull guys at cadimage helped solve it.
Open the wall builder with a wall selected.
When the dialogue comes up, pick stop.
Go to the appearance tab then floor plan. Choose a fill pattern such as empty fill.
Maybe your template had a fill that was not recognised as one of the 9 std fill types used.
(This is what cadimage said to me)
Hope that fixes it for you. It did me
