Calculate number of bricks in overall walls?
How can I calculate the number of bricks in all walls I have in my project?
I know there has to be some volume, which I can divide with the volume of one brick.
But is there a more sophisticated way to do this?
If it is not, then where can I find the total volume of all walls in my project?
Thank you.
13 REPLIES 13
I was looking everywhere of how to do this. No clear instructions. Then I found this, if someone is still looking:
https://helpcenter.graphisoft.com/tips/archicad/library/creating-a-property-object/#Create_a_wall
Complicated, but it works...
Yes property objects can be scripted to do all sorts of calculations including the number of bricks in a wall.
However Interactive Schedules can not use these property objects, they only work in the old list scheme which is fast becoming redundant.
New elements like stairs and railings can't be used in the old list schemes.
The problem with the interactive schedules is they can not do any calculations (except from a simple total),
so they can't calculate the number of bricks in a all - just the area or volume.
poco2013
Mentor
There is no way to do calculations in the standard Schedules in Archicad. you can do this,however, using the the graphical format wizard feature of Lists.
I demoed this with a video on YouTube. You can choose to use surface area or volume as the reference. You can also filter various composites or walls, etc..
https://youtu.be/598lulaB9Xw
With the Format Wizard you can make the list schedule appear nearly identical to the regular schedules.
Be aware that Archicad TS considers lists to be a legacy feature and will not answer questions directly. At least in the USA. So if you have any specific problems -- best to post them here.
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
Thanks, a lot more complicated than I hoped for. But thanks for the input...
