m_ziolo_86
Can't export lists to .doc format.
Hello,
I am unable to export lists to MS Word .doc format. This format can be chosen from the format list in organizer. However, it is not visible when I want to save file via "Save as..." command in File menu. Has anybody managed to export list into MS Word format?
Regards,
M
Archicad 16, Win 8.1
Generate the Schedule you wish to save as DOC and then use the File\Save As command, while still in the Schedule Viewpoint:
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/configuration/saving-from-ar...
m_ziolo_86
Ok, so I am unable to export schedule in .doc format without MS Office installed on my computer... However I do have Open Office installed and it is able to create and open .doc files.
