Can we import revit families into ArchiCAD GDL objects
Hi all
Is there any way to import Revit families to ArchiCAD GDL objects
thnak you
16 REPLIES 16
Scott Davis
Yes, Djorde, you are correct. It's "IF" at this point, but I should know more in the next month or so....I was curious how it worked.
Is IFC a file format? Would my file be something like "window.IFC"
Scott Davis
Autodesk, Inc.
On March 5, 2007 I joined Autodesk, Inc. as a Technical Specialist. Respectfully, I will no longer be actively participating in the Archicad-Talk fourms. Thank you for always allowing me to be a part of your community.
Here is a link to a small PDF that gives a description of the International Alliance for Interoperability (IAI) and Industry Foundation Classes (IFC).
http://www.iai-na.org/about/iaiandinteroperability.pdf
woodster
Scott Davis
hmmm...thanks for the link. It seems that the file format is XML, and that gbXML is already a form of an IFC document. In the future, it seems we mave have an aecXML format for the arch's and eng's.
Still a bit confusing. I still equate this to needing some kind of file "type" that all IFC compliant programs can read and write....basically the DWG of the new millineum.
If you export an ArchiCAD object as an IFC compliant file format, what do you get?
Scott Davis
Autodesk, Inc.
Laura Yanoviak
Good question -- anyone? anyone?
Also, any update on "if" or "when" Revit may be IFC enabled?
UPDATE: Revit Building 8 now has an IFC export feature, however, "It is important to note that this IFC certification for Revit has been achieved for the code-checking view only, and does not guarantee that an IFC exported file from Revit will work with all applications that use the IFC format." per Lachmi Khemlani's review www.aecbytes.com/review/RevitBuilding8.htm
Link
I found this thread after a google search and just wanted to say for the record that this is now possible with the RFA & RVT Geometry Exchange Add-on for ARCHICAD 21by BIM6x.
https://www.bim6x.com/blog/bim6x-announces-revit-families-revit-geometry-exchange-add-archicad
Link.
Djordje
ETA for the 22 AddOn?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Link
Hmmm, an updated AC21 add-on in a few weeks. An AC22 add-on in a few months!
