Change name of the images in DWG export
Mario Sacco
When I export an archicad document 12 in DWG 2007 it changes the name of the external file of the images attached adding a number from 1 to 9. Is there a method to export without changing the original name?
Mario
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
What hapens if You place the bitmaps not by figure tool but the drawing tool?
If the bitmaps are placed by figure tool - they are actualy pasted into the pln not referenced.
Hope it helps,
Best Regards,
Piotr
Djordje
What is the file format of the placed images?
How are they placed?
What is the setting for the image output in your Translator?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Mario Sacco
The images are placed in the drawing as drawing and no as images. The format is jpg, and they are placed both on the layout and project map. The translator is set on "images original format" and force autocad format is not checked.
