Changing shapes pipe/ductwork
Is it possible to adjust the MEP shapes from pipe (circular) to ductwork (rectangular)?
I know its possible with ductwork.
Thanks
1 REPLY 1
David Maudlin
watsermetjou:
I don't see a way to do this, and the Parameter Transfer Between Objects won't work as the MEP pipe and duct objects are not the same subtype. The best solution I see is to use the existing pipe layout as a guide for recreating the run using ducts with the MEP Routing feature.
You should edit your Signature to include your ArchiCAD version for more accurate help in this forum.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
