Cigraph add-ons broken in AC 11(1200)
Dave Jochum
ArchiForma, -Stair, and -Terra all outdated for latest AC build. Nothing on Cigraph website. Fabrizio?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
14 REPLIES 14
__archiben
hi dave - they all seem to run for me: AC11 INT 1200 (it does tell me that i need to update them from the cigraph website though, so i must be running some older versions . . . is that what you mean?)
~/archiben
b e n f r o s t
Dave Jochum
~/archiben
No. The add-ons don't show up in AC and the Add-ons Manager gives me a message that they are outdated. See attached.
Dave Jochum
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Hi Dave,
I still didn't install the latest ArchiCAD 11 (1200) patch so I were in the best situation to check your trouble.
I just downloaded and installed the patch but everything works fine here (look at the attached image).
I'm using a MacBook Pro so I'm in the Apple side like you.
Maybe your add-ons for some "strange" reasons got damaged... please, try to download them again and substitute the old ones.
let me know the result...
Just for Archiben (sooner or later we will meet each other again) you are a really "bad boy"
the new checking update procedure try to help the user in using always the latest versions... don't you trust on us (or better on me)?
Please, when a new update is available, always download it!
If a new update is available this means that in the previous version there was something not working so...
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Dave Jochum
Fabrizio wrote:
...Maybe your add-ons for some "strange" reasons got damaged... please, try to download them again and substitute the old ones.
Friendly
Fabrizio
I downloaded ArchiForma (haven't tried -Stair and -Terra yet) with no better result. It still does not show up in DESIGN EXTRAS. ArchiRotate does.
Dave Jochum
__archiben
did it get moved on your work environment? more importantly, does it show as being loaded in your add-on manager now?
they are all good here (MBP with AC11 INT 1200) . . . i was just about to post this image yesterday right before the forum got busted:
~/archiben
b e n f r o s t
__archiben
... the new checking update procedure try to help the user in using always the latest versions... don't you trust on us (or better on me)?
i trust you - it's just that i haven't launched any of them for quite some time the kind of work i'm doing at the moment really only has call for architerra - and then only rarely. sorry!
cheers fabrizio!
ben
b e n f r o s t
Dave Jochum
~/archiben
No change here. Still reads as outdated. Add-ons are in default location and all others show up as they should (ArchiRotate, RoofMaker, etc.)
Dave Jochum
__archiben
just on the off-chance: are you using the right mac add-on - PPC for the older macs and intel for the new?
~/archiben
b e n f r o s t
Dave Jochum
~/archiben
Good idea, but nope. Using Intel.
Dave Jochum
