Conection Arch 13 and C4d 11.5
Hi! I have problem with connection arch and cinema, I use this add-on http://www.graphisoft.com/products/archicad-solutions/cinema4d_download.html
but when i click "edit selected elements in Cinema4D" cinema opens, but is empty,not load selected elements
and where is button SEND BACK TO ARCHICAD ?
I have in my Cinema 4d plug-in folder, a plugin called ArchicadExchange_1.2 R11, as this and the ArchicadExchange_1.2 R10.5 is the only folders that came in C4d plug-in. What am I missing ???
Eirik
7 Replies 7
Hi
I have exactly the same problem.
Found a solution yet?
I am using AC12 with C4D11.5 so your issue may be unique to AC13 - however when you are in C4D just check that the AC model is not just off-screen. If I remember correctly you can hit the 'S' and/or 'H' key to frame your objects - either to all or to the camera.
Good luck
Emre Senoglu
same problem here (archicad13-cinema4d 11.5), cant get the plugin to work !
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
I have same problem here yesterday, but have done at this morning. i put the previous version "ArchicadExchange_1.2R11" on Plug-ins folder in CINEMA 4D, and install ArchiCAD 12. Then the "Send in ArchiCAD" has appear in "file" menu. and the connection is OK.
To create a new CINEMA 4D object, use the "Design > Design Extras
> CINEMA 4D Exchange > Create new element in CINEMA 4D" from ArchiCAD 12, send back in ArchiCAD 12.
and same steps in ArchiCAD 13, send back in ArchiCAD 13 too.
Good news, "C4D add-on for ArchiCAD 13 public beta test" has update to C4D13-3264win .
http://www.cigraph.it/cigraph/pagetrans.do?view=HOME_NEWS&action=notizie_det&lang=it&pof=0&news_id=2...
Good luck,
Allen.W
Hello
I have the latest Archicad Exchange 1.2R11 in the Plug-ins folder but no joy. I can neither edit any part in C4d (because the model doesn't appear) nor can I create a new part and Send to Archicad (because this doesn't exist in the file menu). Any ideas,solutions massively appreciated.
Hello, ArchiCAD-Talkers.
The Plug-in for ArchiCAD has update to 1.33,
Fixed Bugs
'Send to' command now available in Cinema 4D 64 bit.
OSX crash when using 'Send to' command.
http://www.graphisoft.com/products/archicad/addons/cinema_4d/cinema4d_download.html
Cheers.
Allen.W
Problem: I try use the cinema 4d exchange (1.33) in Archicad (13).. . . and it opens the C4d (11.5) . . . . . and . . . its empty .. . . what i'm doing wrong???
HEEELPPPPPPP
