Albertchliu
Cannot call out the ""photo render setting""
Dear Sir/Madam
I want to make a photo render in the indoor, I have turned on the light already.  But the photo is very dark.
I tried to use the "photo render setting", I clicked the button but no response.   I re-install my Arch 27 but in vain.
Just wonder another other way to increase the lamp light ?
thank you!
Lingwisyer
Guru
Is this with CineRender or Redshift or something else? What type of AC licence? EDU / Full, Solo?
Sometimes, these Palettes are not on the visible screen, which is why you don't see them.
You may have had an external monitor that extended the desktop area of your computer and you moved your PhotoRendering Settings Palette there.
You can try to go to the Work Environment Dialog and set the Workspace Scheme to one of the default ones, hopefully, that will bring your palette back to the screen.
