Create property not applicable to building material
Ahmed_K
Mentor
Hi mates,
i'm working on creating detailled schedule for construction estimation,
i created new propretis
1 - Units in letters : which converti the unit to letters using the IFS expression
STR ( IFS ( {Property:Généralités/Unité} = "ml"; "le metre linéaire est "; {Property:Généralités/Unité} = "m²"; "le metre carré est "; {Property:Généralités/Unité} = "m³"; "le metre cube est "; {Property:Généralités/Unité} = "U"; "l'Unité est "; {Property:Généralités/Unité} = "G"; "le groupe est "; {Property:Généralités/Unité} = "F"; "Forfait "; {Property:Généralités/Unité} = "Pièce"; "la pièce est "; {Property:Généralités/Unité} = "Kg"; "le kilogramme est "; {Property:Généralités/Unité} = "Tonne"; "le Tonne est " ) )
2 - Description Appel d'offres : contain this expression :
TEXTJOIN ( "; "; TRUE; {Property:GƩnƩralitƩs/Descriptiion APS - APD}; {Property:GƩnƩralitƩs/UnitƩ en lettres} )
And it join the description of the element to it's unit in letters ( it's a gouvernement obligation hhhhhhh )
The two defined propreties works well for Walls, doors, windows, beams, all construction elements,
BUT
when it comes to building material , the expressions doesn't work and it shows : "non applicable"
like the attachement
the propretie is available for all classifications to be certain
how can i figure out the problem please ?
Archicad 27
Windows 11 professional
7 REPLIES 7
poco2013
Mentor
FYI:
You did not specify what you want to use "Building material" properties for:
The usage of properties in Building Materials was never defined by Graphisoft and I doubt that even the programmers know its intended usage. In the Chaos of the 23 Beta, I'm guessing it was just forgotten. So you can discount the non-applicable message in BM. It is meaningless.
If you are trying to schedule building materials, their properties are handled exactly as normal properties. In that, the material must be used in the plan and the property and the material have a classification that includes the element they are used in. IOW, there just another property.
Gerry
Ahmed_K
Mentor
Thanks for the reply !
The proprety is used to show the building material description and unit written in letters in the schedule.
When i sxhedule a wall, the peopreties show correctly in the schedule.
When i schedule a Building materiel, propretie field keeps empty and don't read data from the bm propreties...
Archicad 27
Ahmed_K
Mentor
maybe this explains it better
Note that ALL of theese propreties are available for ALL Classifications
Archicad 27
poco2013
Mentor
I am still not sure what you are trying to accomplish? AFAIK-- You can not schedule just Building Materials. As mentioned above, they must first be in the plan
And if in the plan the building material properties just become another property of the element that uses it.
I think the problem may be in the criteria you are using for each of your schedules.
Gerry
Ahmed_K
Mentor
Are you working on the Element schedule i thiknk
can you share a screen shot of wall propreties tab and BM propreties tab please ?
i think i got it, i'm trying to extract material propreties from a composite wall , that's why it didn't work
Archicad 27
poco2013
Mentor
yes i am using a element schedule and assuming a basic wall. If you are using compound walls, you should use a surface schedule -I'm guessing? EDIT -- Also, for composite walls, the Building Material attribute is not applicable but you can work around by using the material name.
My settings:
Gerry
Ahmed_K
Mentor
Thanks Poco2013 !
your right, building material UNDER unother element can't operate formulas, you are using element schedule that's why it works,
So, th best way , is to extract material from the composite, it's possible and that's a powerfull option in archiCAD, and do the join in excel, that's easier,
Just one thing;
* Element schedutle : to schedule elements like wall, slab (calculate area of a wall , a slab area etc )
* Component schedule : to list components of an element : Components of a composite wall with all their data, components of a curtain wall, stair, railing... like listing subcategories
* Surface schedule : only for painting work, it liest the surface , and here the difference : i can build a wall with stucco , and paint it half RED and half BLUE
==> stucco quantitie : From component schedule
painting quantities : From surface schedule
Archicad 27
